Sean's R3W Steering Damper kits ready to ship
SaskMick
Re: Sean's R3W Steering Damper kits ready to ship
Postby SaskMick » Mon Jul 03, 2017 8:23 pm
BinDerSmokDat wrote:Some sort of steering damper is necessary on a Ural.
There is no such thing as a sidecar set-up that is stable on EVERY road crown angle, at EVERY speed, on EVERY road surface.
There are various settings and geometries that work well under a wide range of conditions, but you need a damper.
Sidecar rigs, by their very nature are compromises, not handling like two-wheelers and not handling like 4 wheelers.
I was able to put over 300km on my Sean damper this weekend, a mix of twisty pavement, long stretches of gravel and washboard plus some very challenging rock trails.
It performed very well and improved the bike handling while minimizing bump steer.
Funny, on the rocks and nasty rutted trails I didn't see any perfectly aligned Sportster rigs to compare sidecar geometry with. :roll:
I have ridden my sportster everywhere in my vicinity and there are some very rough tracks. Now that I have uprated the springs the only thing I miss is a reverse gear. It goes fast too, fast for a sidecar rig anyway, I once took it up to 85 mph before I chickened out. For the money invested it's a hard to beat machine.
I form the light,and create darkness: I make peace, and create evil: I the Lord do all these things.
Isaih 45:7 KJV
ARSE !
SaskMick
Postby SaskMick » Mon Jul 03, 2017 8:27 pm
Completely agree. I can get my setup "perfect", only to find that, once laden with a passenger and camping supplies, my "perfect" setup now sucks. A steering damper helps to mitigate this phenomenon.
How does a steering damper do that ? The reason I ask is that mine is redundant 100% of the time, it's still on the bike but it's never used.
Isaih 45:7 KJV
ARSE !
Postby Tomcatfixer » Mon Jul 03, 2017 8:34 pm
I don't know. Hydraulic magic? I guess it just masks steering imperfections. All I know is, having ridden WITH and WITHOUT the damper is day and night difference. Much less fatiguing. It is very much necessary on a Ural, no matter HOW much fiddling you do with the geometry.
Virginia Beach, Virginia, USA
SaskMick
Postby SaskMick » Mon Jul 03, 2017 8:37 pm
I think this bloke could have used a steering damper.. I hope you can watch it.
https://www.facebook.com/ahmed.noshy.56 ... =2&theater
Isaih 45:7 KJV
ARSE !
SaskMick
Postby SaskMick » Mon Jul 03, 2017 8:43 pm
The only time my Harley was fatiguing was when it was out of alignment. I had a CJ ( I've just bought another ) with no steering damper and that was relaxing to drive all the time. If all Urals need a steering damper there must be something amiss with them
Isaih 45:7 KJV
ARSE !
Postby Tomcatfixer » Mon Jul 03, 2017 8:47 pm
So, you're telling me that when you accelerate, your Chiang doesn't yaw to the right? I'm no member of MENSA, but the physics of a right-side-mounted sidecar, one-drive-wheel rig NOT yawing to the right upon acceleration do not compute in my shoulder-mounted gourd. Dare I say that your claims are outlandish and I suspect that you are trolling us?
SaskMick
Postby SaskMick » Mon Jul 03, 2017 8:55 pm
Tomcatfixer wrote:So, you're telling me that when you accelerate, your Chiang doesn't yaw to the right? I'm no member of MENSA, but the physics of a right-side-mounted sidecar, one-drive-wheel rig NOT yawing to the right upon acceleration do not compute in my shoulder-mounted gourd. Dare I say that your claims are outlandish and I suspect that you are trolling us?
The Chang does not have the acceleration to make it pull to the right, it could not pull the skin off a rice pudding :) The sportster does though, with or without the steering damper.
No I'm not trolling.
Isaih 45:7 KJV
ARSE !
SaskMick
Postby SaskMick » Mon Jul 03, 2017 9:30 pm
The problem with steering dampers as I see it is most people get them to cure a steering wobble ( as did I ). They install a steering damper and they think it has fixed the problem, but the problem is still there, they just stuck a band aid on it, it does not fix an alignment issue. Excessive tyre wear is often a symptom of bad alignment that no steering damper will fix.
PS it also makes the engine work harder than it needs to, reduces speed as well.
Isaih 45:7 KJV
ARSE !
solo1966
Postby solo1966 » Sun Jul 09, 2017 9:07 pm
Just ordered one hope they are as good as the stories.
:foilhead: Love my GOD,country,and fear my government,2017 GU
SaskMick
Postby SaskMick » Mon Jul 10, 2017 3:02 am
solo1966 wrote:Just ordered one hope they are as good as the stories.
It might make a wobble less noticeable but it will not stop your tyres from wearing out quickly.
Isaih 45:7 KJV
ARSE !
Postby BinDerSmokDat » Thu Jul 13, 2017 7:02 pm
Saskmi, order one or STFU.
Stop stepping all over Sean's sale thread.
Go to some other room and discuss steering dampers.
Penrod
Postby Penrod » Thu Jul 13, 2017 7:47 pm
BinDerSmokDat wrote:Saskmi, order one or STFU.
I agree.
Live in Maine. Retired.
motovate
Postby motovate » Tue Jul 18, 2017 7:06 pm
I just put on one of Sean's RW3 Steering Damper. Pretty easy to do - real bolt up. I did jack up the front wheel until it was just off of the ground to release the pressure on the front shock bolt. Made it easier to get the bolt out. Other then that it was a sit down and unbolt a couple of bolts and stick it on. I loosened up the stock one and ran it around on my shaky old dirt roads - I could sure feel the difference. Simple order and he shipped it right out! I Like IT.
LBM
Penrod
Postby Penrod » Wed Jul 19, 2017 5:12 pm
Just rode my cT with Sean's steering damper 281 miles through the mountains of western Maine, New Hampshire, and Vermont and into New York state. It is certainly more work driving a Ural that far in a day (I'm 68) than in a car, in mid 80's temperatures. But- Sean's Damper is outstanding, some of the roads were very rough, a never a wobble. Get one.
sean0262
Postby sean0262 » Thu Jul 20, 2017 7:55 am
Again Saskmick, What is the Ural you ride? If I'm mistaken, a H-D Sportster is nothing like a Ural. I would surmise from my experience that the Ural leading link front fork system is nothing like a modern 39mm Shawa hydraulic front fork of the Sportster. Let me check in my shop full of motorcycles.......... Nope, there nothing alike. Again, you were saying???? You know there is never a day when I would want to argue with an IT professional. Because I know nothing about computer technology. How much experience do you have with Urals? Because I have decades. If you would like to carry on this conversation in a more productive way. Please feel free to send me a PM and I will send you my phone number so we can best communicate or differences. I'm very approachable and easy to speak with. As you can ask numerous Soviet Steeds members. I look forward to hearing from you.
Hey Folks, I'm looking for a solo Ural motorcycle. Any machine will do. from a Wolf, Solo or just a rig without it's sidecar. drop me a PM
Sean's R3W Steering Damper Kits for sale viewtopic.php?f=13&t=45227&p=563367#p563367
R3W Steering Damper Reviews http://sovietsteeds.com/forums/viewtopi ... 11&t=44242
Return to “The Gray Market”
