Fuel Line Disconnect
W0X0F
Postby W0X0F » Wed Dec 15, 2010 11:23 am
Found a source for fuel line crossover disconnect (same as Raceway)!
http://www.aircraftspruce.com/catalog/appages/quickdisline.php
P/N 05-01035 is the part I used. It says it may not be compatable with some alcohol based auto fuels, but mine has been leak free for over a year!
I don't know where we're going, but I'm sure it involves a handbasket!
In Dog Years, I'm Already Dead
2008 Patrol
"Старый Белый медведь"
Spyder
Re: Fuel Line Disconnect
Postby Spyder » Wed Dec 15, 2010 11:25 am
Aside from the obvious, what do you use it for? What is it's utility to you?
Spyder
'07 Gear-up - "War Pig" with 1945 MG-34 - "Buzz Kill"Image
"Why you buy motorcycle is broke from factory?" - Ukranian vendor representative at work
W0X0F
Postby W0X0F » Wed Dec 15, 2010 11:27 am
Allows disconnect of the fuel crossover without spillage (easy tank removal)!
2008 Patrol
Spyder
Postby Spyder » Wed Dec 15, 2010 11:29 am
Gotcha :cheers:
Spyder
matman1972
Postby matman1972 » Wed Dec 15, 2010 1:09 pm
W0X0F wrote: It says it may not be compatable with some alcohol based auto fuels, but
yeah, but neither is the rest of the bike (floats....)
2000 tourist- The Wagon Queen family Truckster
Estamos copados
Confusion to our enemies!
Conan..... What is best in life?
Zaphod for President!!
piney
Postby piney » Wed Dec 15, 2010 2:09 pm
Thanks for the link i ordered 2 for the price of 1 thanks Piney :clap:
1995 Sportsman 2005 Patrol 2005 Gear Up
chicagorandy
Postby chicagorandy » Wed Dec 15, 2010 2:50 pm
I followed a previous post and use the connectors from an outboard motor fuel tank. Same principle and available at your local megamart, hardware store, marina etc.
That cross-over line is a royal PIA when you need to pull the tank - like if they 'wisely' chose to put the headlight relays under there - lol
ChicagoRandy
Former Ural driver of Tovarishch - 82,825 since new - sold 08/14/11
1986 Kawasaki Voyager XII - 1200cc's of two wheel bliss
"Down the highway of life at smiles per hour, with special attention to ignorant and blind cagers"
W0X0F
Postby W0X0F » Wed Dec 15, 2010 5:43 pm
Look what I just receivef!
Greetings!
Our records show that you purchased quick disconnect fittings from Aircraft Spruce under or or more of the following part numbers:
05-01035
05-01036
05-01037
05-01038
We want to make you aware that these fittings have used Buna-N o-rings which may not be compatible on a long term basis with alcohol based fuels such as auto fuels. These o-rings can swell over time leading to blocked fuel flow. If you are using alcohol based fuel we encourage you to inspect these quick disconnects for swelled o-rings and replace the fittings if necessary. These fittings will soon be available with viton o-rings which are more compatible with alcohol based fuels.
Please let us know anytime we can be of service.
Aircraft Spruce & Specialty Co.
Customer Service Dept.
2008 Patrol
mgibson61611
Postby mgibson61611 » Wed Dec 15, 2010 7:40 pm
And what was the benefit of us going to E10 fuels? I wonder how much fun E15 will be!
Mark
2011 Tourist
1970 Triumph T120R (back among the running)
2009 HD FLHR
2011 HD FXDWG
Z-Man
Postby Z-Man » Wed Dec 15, 2010 10:58 pm
W0X0F wrote:Found a source for fuel line crossover disconnect (same as Raceway)!
I have the same ones. They just sent me an email about the Buna-N o-rings possibly swelling up and blocking the fuel flow. They also said they're coming out with some viton o-rings soon.
'10 Ural Gear-Up (другая женщина the "Other Woman")
K&N Air Filter, Gossie Needles, 127.5/42 Jets, past 20K km and running strong. Someone stole my cats.
What broke and needed fixing: speedometer gear, hack stub shaft.
"Ride today, because you don't know what tomorrow brings"
cdscoot
Postby cdscoot » Thu Dec 16, 2010 10:20 am
BMW has one of these on some of their bikes. They are not made of nylon that will eventually crack and the o rings are made for fuel. They are also made of a black reinforced plasticon one end and metal on the other. They are about 50 bucks, but you will only do it once. :wink:
The part #s are 13 31 7 659 120 and 13 53 7 700 800 . These are the numbers on my invoice - should be BMW numbers.
Craig
2010 Patrol T
2016 BMW R1200GS
co_g30
Postby co_g30 » Thu Dec 16, 2010 11:24 am
tried to install the adapter shown in first post, could not get it to mate together easily once installed. angles were wrong coming from my tank....maybe it's easier on the newer models but on mine, I could not get it to work right, ended up putting the stock hose back on.
and yes, big mess if you don't drain the tank first, and even then....
CO_G30
2014 Ural Patrol "Scarlett"
1987 BMW R80 "Brigitta"
reimerdavid
Postby reimerdavid » Sun Dec 19, 2010 6:16 pm
I had the same experience with my 2009 Gear-up.....Went back to stock line
URAL CT
Postby URAL CT » Sun Dec 19, 2010 9:35 pm
I have the metal ones (both male/female). I made my crossover fuel line long enough for me to easily separate 'em. I made sure that I can separate the two with ease before I added fuel to the tank. Works like a charm for me. I can remove my tank without emptying it. Of course I wait til the tank is almost empty (if i have to remove the gas tank) before I work on the rig. :D
CT
2007 Patrol
Plano, TX
cdscoot
Postby cdscoot » Sun Dec 19, 2010 9:48 pm
Just had mine off today to work on it. I also lengthened the hose using gas line 1/4 ". If you leave enough slack it's a snap !
Craig
2010 Patrol T
2016 BMW R1200GS
Return to “The Gray Market”
