Stuck valve covers (chang jiang)
Orgoth225
Postby Orgoth225 » Mon Oct 31, 2016 6:46 pm
Ok, I have checked the spark, cleaned the carburetors, and made sure the timing is good on my chang. The bike still only want to start once in a blue moon. The times it does work there is no power. At this point I am going to make a guess that my valves probably need adjustment. The issue however being that the screws had been last screwed to the point of them being stripped and stuck. There is still some thread for the driver to fit but I have sprayed everything from wd40 to pb blaster with no luck of getting it loose. Any suggestions on getting these things off withiout destroying my engine?
brianural
Re: Stuck valve covers (chang jiang)
Postby brianural » Mon Oct 31, 2016 6:49 pm
maybe some heat, use a small propane torch and heat them up. Saw a video the other day of a guy using candle w@*, melted into the threads. Good luck
2011 HD RGU
2003 Honda VTX1800 - sold
2005 Honda VTX1300 - sold
1956 IMZ M72 (bought in pieces, oh crap what have I done) Hope to have on road in 2018
dneprlover
Postby dneprlover » Mon Oct 31, 2016 7:12 pm
I presume a sidevalve
Postby Snakeoil » Tue Nov 01, 2016 10:26 am
Doubtful that Loctite would hold up under flathead temps. But they may have used a hi-temp product.
DL suggestions are all good stuff. To tag on to those, go to Harbo Freight nad get a hand impact wrench. No bike shop should be without one. That should break them free if anything will.
I'm not personally familiar with these engines. But can you not simply drill the heads off the screws to remove the covers and then remove the remaining stubs of the screws with pliers?
Postby Lmo » Tue Nov 01, 2016 12:45 pm
The tool mentioned is called an "Impact Driver". The benefit of the tool is that as you strike it, it twists the screw simultaneously. I bought my Vessel in 1967 when I started working in a Honda shop. About $50 now I think. $$$ well spent.
Heat is then a more forcefull method which can be tried.
I've found that a 150W electric soldering iron does a pretty good job, without the open flame issue. Puts the heat exactly where you want it without substantially heating everything around it.
Postby rivers » Tue Nov 01, 2016 1:22 pm
Snakeoil wrote: get a hand impact wrench. No bike shop should be without one.
+10 A MUST HAVE tool. Stuck, rusted, corroded bolts respond much better to quick impact/shock loads rather than to progressively increased torque. The slot in the bolt head usually goes south before the threads break free. Any auto parts store should carry them. Even the cheap China ones work and hold up a long time.
immulmen
Postby immulmen » Tue Nov 01, 2016 1:42 pm
Is this a flathead or OHV???????????????????
CJ750 M1M
1997 Ural converted to 2WD With Chang OHV engine.
Postby gobium » Tue Nov 01, 2016 3:16 pm
immulmen wrote:Is this a flathead or OHV???????????????????
I bet it is flathead
Good luck, ride safe.
Good bye all
made some great friends here
Postby Lmo » Tue Nov 01, 2016 3:37 pm
OHV socket head ??? :P :?
dneprlover
Postby dneprlover » Tue Nov 01, 2016 4:32 pm
Lmo wrote:OHV socket head ??? :P :?
It''s a post 86. 12v Flathead with an electric boot.
Postby Snakeoil » Tue Nov 01, 2016 7:39 pm
Yes, thanks for correcting me. For some reason, I started calling it a "wrench" and have no idea why. Gray hair I guess. :feelsgood:
The Horror Fright versions are quite good. The bits tend to be glass hard. But they are lifetime guarantee. Save your receipt. I think I've gotten at least 3 new ones over the years, just because the bits broke.
I still have the first one I bought, way before the internet, from JC Whitney. This was when you clipped out the ordering form and mailed it in with your check. Same tin box as your Vessel. I don't think I ever destroyed any of the bits. Deformed a few, but never shattered any. You can get replacement bits at places like NAPA. But they cost more than the tool and bits from HF.
Users browsing this forum: Gunfighter and 3 guests
