oil filter question
505stevec
oil filter question
Postby 505stevec » Sat Mar 05, 2016 11:09 am
I ordered an oil filter and O-rings/crush washers for an upcoming lube service. The filter sent is paper wrapped around the filter. All the filters I have seen look metal with holes. This looks shorter also.... NOOB Question of the day... Is this the right one? :o
505stevec
07 Gear Up
Re: oil filter question
Postby Albuquralque » Sat Mar 05, 2016 11:21 am
Yes it will work. That's the difference between the Russian paper filters and the EMGO filters.
The Russian paper ones (the one you have) are a lot easier to install.
Postby Albuquralque » Sat Mar 05, 2016 11:22 am
BTW - what year / model rig do you have?
505stevec
Postby 505stevec » Sat Mar 05, 2016 1:05 pm
Thanks for the help! Mine is a 2007 Gear Up. Another question... I was looking for a sidecar windshield. They are spendy here in the states. I found one for a 650 cc Ural in Germany on Ebay. Will that fit? Thanks
505stevec
07 Gear Up
Postby Albuquralque » Sat Mar 05, 2016 4:24 pm
The sidecars haven't changed much over the years. Do you have a link to the one you are referencing. I'd hate to tell you yes it will fit and find out later it doesn't.
505stevec
Postby 505stevec » Sat Mar 05, 2016 6:45 pm
If you search Ural Windshields on MC part, you will see a few sidecar windshields. The one from Germany is the one I'm looking at
505stevec
07 Gear Up
Postby Albuquralque » Sat Mar 05, 2016 7:49 pm
505stevec wrote:If you search Ural Windshields on MC part, you will see a few sidecar windshields. The one from Germany is the one I'm looking at
Yes that should fit and it even looks like it comes with the brackets that mount inside the sidecar.
I'm thinking you saw the $60.00 shipping price tag as well.
505stevec
Postby 505stevec » Sat Mar 05, 2016 9:23 pm
Yeah but for a new one here the cheapest I found was $288 and up to $400.. Thanks for the help y'all
505stevec
07 Gear Up
irondad01
Postby irondad01 » Sun Mar 06, 2016 7:59 am
Where are you located? A lot of guys on here took their windshield off and may part with it cheap.
Ural tub on Yamaha 1300
VW trike
Suzuki S-40 rebuilt to look like 50s-60s British single
505stevec
Postby 505stevec » Sun Mar 06, 2016 8:37 am
I am in nm.about 70 west of Albuquerque.
505stevec
07 Gear Up
irondad01
Postby irondad01 » Thu Mar 10, 2016 6:42 pm
I'm too far away to help you out. Maybe you should put a wanted to buy post on the black market forum. As it is, your windshield question is lost in your oil filter post. In 2013 Ural changed the snap arrangement on the skirt of the windshield. They went to a twist fastener. I don't think the grommets are the same size. Carl
VW trike
