Off-Road Tires
GillaFunk
Re: Off-Road Tires
Postby GillaFunk » Thu Feb 25, 2016 11:47 pm
siberman1 wrote:
Does anyone use Heavy Duty tubes? Rim Strip questions anyone?
IRC heavy duty tubes. : Rockymountainatv
Gorilla tape rim strips. :D
Sgt. USMC 0311, 8156
Ammo
Re: Off-Road Tires
Postby Ammo » Fri Feb 26, 2016 12:10 am
+1 on the tape - I toss out my rubber first change and break out the speed tape ;-)
Mac
13 Patrol T
04 GSA
96 ATK605
keetmanaa
Re: Off-Road Tires
Postby keetmanaa » Fri Feb 26, 2016 5:46 pm
rivers wrote:PS: when conditions get really nasty, having chains in your trunk is a good back-up plan.
Do you have a source for chains or did you fabricate them yourself?
2015 Gear Up
2010 Yamaha WR250R
2004 DL650 V Strom
Re: Off-Road Tires
Postby rivers » Fri Feb 26, 2016 6:18 pm
Old Timers Garage in Poland. Member here Gillafunk had a thread awhile back about building and selling some also.
Re: Off-Road Tires
Postby siberman1 » Fri Feb 26, 2016 8:03 pm
I ordered 4 of the "DURO Hf307 400 19 6pr Tt" from edgextremesports.com. There did not seem to be any problems, order went through as it ought to in today's internet world. Price was as advertised. So...
I'll post when the 4 tires arrive and go from there.
keetmanaa
Re: Off-Road Tires
Postby keetmanaa » Tue Mar 01, 2016 6:32 pm
I've got the 307's on the way and wonder what tire pressures y'all have found best off road, given no rim locks. I carry an electric air pump so can re-inflate when going back on pavement at day's end.
2015 Gear Up
2010 Yamaha WR250R
2004 DL650 V Strom
DaveO
Re: Off-Road Tires
Postby DaveO » Tue Mar 01, 2016 6:57 pm
keetmanaa wrote:I've got the 307's on the way and wonder what tire pressures y'all have found best off road, given no rim locks. I carry an electric air pump so can re-inflate when going back on pavement at day's end.
I wouldn't, and don't, ever bother dropping the pressure....IMO the tires are too narrow for it to help much anyhow, and with the possibility of shearing off, or ripping out a valve stem..... it's definitely a no-no for me
IMO... THE key to doing rough stuff with a ural is to Never Ever Ever lose Your Momentum!...even if it means you have to attack at full throttle, and you will....cuz....once you bog down ....or sink in.... or turned sideways.... you may be just screwed hard...especially if you're alone
For me it's pretty much just dump the clutch and hold on....
I have a modicum of experience with off-roading these....they will need to be repaired more and upgraded somewhat too....depending on what you have in mind... :)
'00 CMSI Patrol
Ammo
Re: Off-Road Tires
Postby Ammo » Tue Mar 01, 2016 7:02 pm
+1 momentum is key and neither do I bother with airing down
Mac
13 Patrol T
04 GSA
96 ATK605
Re: Off-Road Tires
Postby rivers » Tue Mar 01, 2016 7:12 pm
I just run dealer/factory recommended pressure year round everywhere. These rigs don't have the power or gearing for rock crawling so no need to air down there. For what sand,mud stretches or hills I encounter I find speed, momentum and keep the wheel spinning/digging works for me. Now if I were crossing the Sahara, I'd air down some. Otherwise just haven't had the need. Do I get stuck sometimes? You betcha.
Re: Off-Road Tires
Postby siberman1 » Tue Mar 01, 2016 7:20 pm
I bought a Maasdam Rope Puller like Mr.Cob recommends. I have yet to modify it with a hook and pulley added, GHGoodwin on SS did that. I will either do the mod on the puller or just throw the whole thing in the trunk when heading out - probably to MOAB 2016! I bought the rope puller from Amazon on sale with 75' rope for only $52, free shipping, so I thought that was a good deal. Even if you don't use the rope puller, that much rope attached to another Ural would be pretty helpful.
Re: Off-Road Tires
Postby siberman1 » Tue Mar 08, 2016 11:48 am
siberman1 wrote:I ordered 4 of the "DURO Hf307 400 19 6pr Tt" from edgextremesports.com. There did not seem to be any problems, order went through as it ought to in today's internet world. Price was as advertised. So...
The 4 tires arrived by brown truck all wrapped up in plastic wrap - looking like one big fat tractor tire. No problems with the order, free shipping was fine.
I suppose if you think you need some of these 307 knobbies, it would be a good idea to get some while the price remains relatively low. Things always get more expensive and/or may not be available at a moments notice if you want them. If I get ambitious, I'll put 2 on for MOAB. JMO
tony147
Re: Off-Road Tires
Postby tony147 » Fri Jul 22, 2016 7:54 am
GillaFunk wrote:
IRC vegas off road tours duty tubes. : Rockymountainatv
I suggest you to use maxxis tire for off road tires. I use it from last three years they are durable and not so expensive.
Doc
Re: Off-Road Tires
Postby Doc » Sun Jul 24, 2016 2:26 am
That is a great picture!
:cheers:
HMCS(DSW/SCW) USN Retired
2015 Ural Gear-Up
2003 Indian Chief
"IF YOU CAN'T DODGE IT, RAM IT"
Las Vegas, NV :cheers:
makarov
Re: Off-Road Tires
Postby makarov » Mon Jul 25, 2016 7:21 am
Heidenau K37s are a good tire for on and off-road use. Like other K37 converts, once the original tires wore out I switched to K37s and have run them since. Yes they are more expensive than a cheap Russian street tire but you get what you pay for :D .
Oh, on the 3-wheels Ural a semi-knobbie like a K37 isn't going to be squirrely like a 2-wheel bike might be. I've also run full knobbie Kenda tires on the street and they didn't feel squirrely either just noisier.
Check my post with photos on K37 tire wear on this thread :
http://www.sovietsteeds.com/forums/viewtopic.php?f=10&t=44912
2004 Ural GearUp 2WD
Steve7959
Re: Off-Road Tires
Postby Steve7959 » Mon Jul 25, 2016 7:43 am
+ 1 for K37's
I re-rubbered just before my recent Spain trip with K37's. They got 1,000 miles of serious abuse on mountain roads and are showing negligible signs of wear to date.
They handled well on tarmac, rough and wet
....... and this was with a seriously loaded rig
Steve
2004 Ural Dalesman
'91 Honda VFR 750
'98 BMW F650
Sometimes I sit and think
............. mostly I just sit
