Ural Tool Kit
mouka
Ural Tool Kit
Postby mouka » Thu Jan 07, 2016 7:23 am
I have watched a few videos of various Ural motorcycles, and I have noticed that they all came with a tool kit. Unfortunately mine does not have one. It has a hand pump but no tool kit whatsoever.
What tools are in the tool kit, and can I easily find those tools from hardware or auto part stores?
Thanks
2005 Honda Sabre 1100
2003 Ural Tourist
1998 Honda Aero 1100
Re: Ural Tool Kit
Postby Albuquralque » Thu Jan 07, 2016 12:25 pm
You can easily build a tool kit with tools from Harbor Freight or other local hardware store. The major items are:
Screw drivers: phillips & flat
Combination Wrenches: 10mm, 12mm, 13mm, 17mm, 19mm
Large crescent wrench
Pliers: Needle nose & standard
If you want a socket set, 3/8" drive metric (Harbor Freight has them for cheap)
Tire irons if you want (again, found at HF)
The only specialty tool that I can think of is the pin wrench used to remove the wheel bearing retaining nut.
scottolds
Re: Ural Tool Kit
Postby scottolds » Thu Jan 07, 2016 1:15 pm
Albuquralque wrote:You can easily build a tool kit with tools from Harbor Freight or other local hardware store. The major items are:
One thing to check on Harbor Freight socket sets is make sure they include the sizes you need. I bought one about a year ago and it didn't have a 12 mm. Fortunately, I have other 12mm sockets but it seems silly to me that they don't include that size.
2009 KLR650
1987 Honda VF700C Super Magna
1994 Kawasaki Voyager XII
http://www.rokkitrider.com
mouka
Re: Ural Tool Kit
Postby mouka » Thu Jan 07, 2016 1:48 pm
Albuquralque wrote:The only specialty tool that I can think of is the pin wrench used to remove the wheel bearing retaining nut.
Is this the wrench that has two "teeth" sticking out of its side? And if yes, can I find it somewhere?
2003 Ural Tourist
Re: Ural Tool Kit
Postby Albuquralque » Thu Jan 07, 2016 2:33 pm
Yes it is.
One other special tool you will need is the spanner used to tighten the exhaust coupling nuts and the wheel bearing lock nuts.
Re: Ural Tool Kit
Postby Albuquralque » Thu Jan 07, 2016 2:39 pm
Re: Ural Tool Kit
Postby Albuquralque » Thu Jan 07, 2016 2:42 pm
Here's an adjustable pin wrench at Harbor Freight:
http://www.harborfreight.com/adjustable ... 36554.html
Re: Ural Tool Kit
Postby Albuquralque » Thu Jan 07, 2016 2:46 pm
Here's a link to a spanner that should work for adjusting the shocks, tightening the muffler coupling nut, and also the wheel bearing lock nuts:
http://www.cyclegear.com/STOCKTON-TOOL- ... ner-Wrench
mouka
Re: Ural Tool Kit
Postby mouka » Thu Jan 07, 2016 4:33 pm
The Harbor Freight link is extremely useful. That's exactly what I like: Cheap and versatile tools.
As for the spanner, I have them for my Honda motorcycles, so I should be set for the specialty tools. The other stuff, I had a ton of lying around.
Thanks for the tips guys. You rock!
2003 Ural Tourist
bluesman
Re: Ural Tool Kit
Postby bluesman » Wed Mar 09, 2016 11:48 pm
Is the outfit 100% metric?
2015 Gloss Black Retro Classic
2007 Harley FLSTC, Springer Classic
1942 Harley WLA
Re: Ural Tool Kit
Postby INSUBORDINATOR » Thu Mar 10, 2016 12:58 am
bluesman wrote:Is the outfit 100% metric?
YES, So is the URAL.
bluesman
Re: Ural Tool Kit
Postby bluesman » Thu Mar 10, 2016 7:49 am
Thanks
1942 Harley WLA
Re: Ural Tool Kit
Postby Albuquralque » Thu Mar 10, 2016 8:38 am
99.9% metric. The two allen bolts that hold the rear brake pads on are not metric.
Re: Ural Tool Kit
Postby siberman1 » Thu Mar 10, 2016 10:57 am
I have the full tool kit, but made my own carry-case out of oil-cloth or whatever it is called. It was an outdoor table cloth with like shiny vinyl/plastic on one side and heavy weave cotton or something on the other side. I gout it at a 2nd hand store for $1, since it is a close match to "sage green".
I also have a copy of the owners manual in a 3-ring binder for daily use in the trunk. I wanted to keep the original one clean and nice shape. I did take the electrical diagram to the office and printed all of it in color full size. I think it was 8 letter pages, then taped them all together where they fit. This is also in the binder.
It just takes time to measure everything and sew the pockets, but easy to do even for a Ural owner.
phliparoonie
Re: Ural Tool Kit
Postby phliparoonie » Fri Mar 11, 2016 8:29 am
siberman1: I have a cat's paw pry bar in my tool kit, too. But you seem to have gone overboard with redundancy and authenticity. :lol:
