Identity crisis
propwash
Re: Identity crisis
Postby propwash » Wed Jan 06, 2016 5:54 pm
Mostly looks MV to me.
Is there a placard on the tank toolbox?
Are there star stamps on the engine, transmission, wheels?
The green color under the brown looks right for a MV machine.
The sidecar is odd - should have multiple mounts (or holes if the have been removed).
Are there multiple holes in the side of the sidecar for mounts (axe, shovel, gas can)?
Inside the trunk area should be ammo container mounts.
Should have front and read machine gun mounts.
mtnepracue
Re: Identity crisis
Postby mtnepracue » Wed Jan 06, 2016 6:08 pm
I think not be able to identify ... It's just a block from the bike 2vd diferentsial..On collected from different parts of the bikes. It turned out not bad - but electric starter :? ..We'll call these "improvements" "dung-farm" - it spoils the appearance of good motorcycle :beerchug:
1986 ZiL 157 military truck
1970 К-750 sidecar
1955 М72
1983 Dnepr 10-36
1970 Barkas B 1000 minibus
2000 VAZ 2104 "Batmobile"
2006 1200сс V4 custom bike "Death Star"
..and much more :cheers:
propwash
Re: Identity crisis
Postby propwash » Wed Jan 06, 2016 6:14 pm
A regular 2WD (differential only) frame will not have the bosses welded on the frame for the 2WD locker handle.
I agree the electric starter and the battery in the sidecar (probably for said starter) are pretty bad looking.
EDIT - I think the sidecar body has been swapped.
dneprlover
Re: Identity crisis
Postby dneprlover » Thu Jan 07, 2016 7:54 am
rbike wrote:Headlight housing is of Dnepr mt9. 3 bulbs + 1 fuse.
Mb750 1 light + 1 fuse.
The extra lights are different
Kirov750
Re: Identity crisis
Postby Kirov750 » Sun Feb 21, 2016 3:48 am
propwash wrote:Mostly looks MV to me.
Yes, there is one about differential system " use it with care ".
Starstamps found on engine. Gearbox is not its original, PO gave the original gearbox.
Haven't seen any holes on the sidecar, but i suspect on the side is a placement for showel.
In the trunk, its just flat and is used space for 12V battery for el-starter. No mount for MG's
Dnepr MW/MB 750 (1969)
