overfilled oil?
torque
overfilled oil?
Postby torque » Wed Jun 07, 2017 3:02 pm
I think I may have overfilled the engine oil last week. Dipstick reads 1/4 to 1/2" above the full mark.
1/4" if it only sat overnight.
1/2" if it has set for a week.
Should I drain some out, or let it run?
2013 Ural "T" (custom)
08 Linhai Aeolus 300 (sold)
09 Yamaha Majesty
in the mountains of southern West Virginia
"There are many paths from birth to the grave. They all work."
Emoore
Re: overfilled oil?
Postby Emoore » Wed Jun 07, 2017 3:46 pm
This is a great question. Mine is like that as well, even after putting in the amount the book says.
Im interested in the responses.
Sent from my SAMSUNG-SM-J320AZ using Tapatalk
Ernest
2003 Patrol (Medusa)
2012 Ural T Olive (Roulette)
2017 Ural CT ( Grey Hex)
Wake Forest, NC
"Train with what you have, Not what you wished you had"
Michal
Re: overfilled oil?
Postby Michal » Wed Jun 07, 2017 4:08 pm
1/2" above max mark is not problem at all. 1" above could be close to crankshaft. The only concern is that crankshaft should not be hitting oil while cranking at high speed.
By my deeds I honor him, flat twin.
Михаил
2002 Днепр 650 Молодежный Чоппер (КМЗ-8.157.022)
2005 Урал 750 Спортсман (2WD)
Lee Pape
Re: overfilled oil?
Postby Lee Pape » Wed Jun 07, 2017 5:25 pm
Are you screwing down the dip stick or just resting it on top of the threads? It is just supposed to rest on top of the threads when checking the oil. During the 650 engines we used to over fill the crankcase by a half a quart in the hot weather to help with cooling.
But, together we have it all.
Penrod
Re: overfilled oil?
Postby Penrod » Wed Jun 07, 2017 7:43 pm
Lee Pape is right...engine dipstick is unscrewed and just sits on the rim to check the level. Transmission level just at the bottom of the threads on the fill hole, final drive dipstick screwed in to check level.
2015 cT Special Edition Dark Force
Live in Maine. Retired.
hillbillybob
Re: overfilled oil?
Postby hillbillybob » Mon Jun 19, 2017 7:34 am
A syringe in about the 100 ml size, can be handy to have in the shop. Can always extend it with a length of fuel line, for those harder to reach places. An example.....https://www.ebay.com/i/132142997522?chn=ps&dispItem=1
2006 Ural Troyka "Boris" (38/125 out, 40/135 in, much better)
2000 BMW R1200C "Schultz"
1999 BMW R1200C "Dooley"
2011 Chinese 150cc Scooter "Johnny" (13,262 breakdown free miles)
Re: overfilled oil?
Postby stagewex » Mon Jun 19, 2017 8:22 am
Overfill, no big deal.
Underfill, a really big deal.
2007 Ural Patrol, 2006 Yamaha TW200, 1995 BMW K75, 1969 BMW r60/2US
Michal
Re: overfilled oil?
Postby Michal » Mon Jun 19, 2017 9:34 am
stagewex wrote:Overfill, no big deal.
... however there is a limit for safe overfill.
My wife's coworker got a corporate pool car for short business trip. He was told that this particular car consumes oil a bit so it's advisable to check oil level at gas stops and fill if necessary. So when he stopped for the first fuel fill-up he opened the hood and opened oil fill cap, the only clearly visible cap on the top of the engine.
He didn't see oil level, obviously, so he filled one 1 liter bottle. Yet no oil level in sight, so he bought 5 liter (1.3 gallon) canister and poured all in.
Yet again, so he bought next 5 liter oil .... and again until the oil level was just under the filling cap.
The engine made 200 yards until one piston with connecting rod broke. The remaining rod on crankshaft almost cut the engine apart.
Михаил
Re: overfilled oil?
Postby hotflash44 » Mon Jun 19, 2017 9:49 am
my 2016 gu dip stick has the full mark as a v shaped bend in the dip stick i assume that in the middle is full or is it the top of the bend? were talking 1/4 in either way so no biggie IMHO.
drive a 2016 gear up asphalt grey .Air America CIA circa 1967/8 Vung Tau Viet Nam USS Tutuila ARG-4 (AND JUST A TOUCH OF AGENT ORANGE!)
Re: overfilled oil?
Postby Peter Pan » Mon Jun 19, 2017 11:01 am
Stagewax, you are confirmedly wrong:
Once upon the time in 1982 I filled the engine oil to the upper mark at freezing temperatures (not even above the mark!)...35km later I blew the engine of my first bike CB125. Once the crank started to punch the oil it created foam and blew the oil through every single housing partation. My friend and I arrived at the the concert with oiled trousers and boots.
Might be on a Ural there is more tolerance, but I would not like to test that. Therefore the syringe with a piece of hose for the final drive oil comes very handy.
Sven
PS: Saturday I had a story like Michael told...Filled some Bacteria culture from one bottle into another one...I was so concentrated in not to loose any drop in the shop, that I didn't notice the new bottle had a hole...I noticed it after 1,5liter were pored into a 0,6l bottle :? All the floor was wet. That can happen only at the optiker's shop where you just encharged new glasses.
Sophie Travelair
Patrol 2013 a Jim Petitti special.(RIP)
8 weeks 12.000km Oregon - Alaska - Oregon, now in CR 39.000km and counting.
With a DIY foam air filter the rig runs well even in tropical rain. The air box looks then like an aquarium. :moto:
Final drives: 1. at 5000km, 2. at 34.000km(+friction plates)
transmission: 1. 39.000km. 2. on its way.
Mothra35
Re: overfilled oil?
Postby Mothra35 » Mon Jun 19, 2017 11:49 am
Wouldn't the crankcase breather tube just blow out most of it anyway into the airfilter or atmosphere?
--2005 Ural Tourist--"Маня"
My U-Tube
---Oliver---Оливер--- :headbang:
Re: overfilled oil?
Postby stagewex » Mon Jun 19, 2017 2:39 pm
Yeah, I am talking about a Ural... nothing else.
Re: overfilled oil?
Postby gobium » Mon Jun 19, 2017 2:44 pm
If it worry you
Let liltle oil out.
Not at drain plug
Do it at oil filter housing
torque
Re: overfilled oil?
Postby torque » Mon Jun 19, 2017 2:51 pm
gobium wrote:If it worry you
Let liltle oil out.
Not at drain plug
Doesn't seem to be foaming. If I let it set for a day -- it's about 1/4" above the full mark (dipstick unscrewed). If I let is set for a week, then it's no more than 1/2" above the bull mark. I figure if 1/4" is ok, then by the time I turn the engine over with the kicker 4-5 times to prime the carbs and circulate some oil, then it's probably around 1/4" at that point anyway.
09 Yamaha Majesty
Manscout
Re: overfilled oil?
Postby Manscout » Tue Jun 20, 2017 3:43 pm
I accidentally over filled a little bit this weekend. Here is what I found with my bike since you asked. If I am riding around town (up to 45mph) I never have any issues. However, once I hit highway and interstate speeds, and I get 3rd gear with high RPMs; I have issues. It leaks out of the dipstick area and down the side of the engine. I have my breather hose rerouted down towards my kickstand, and it coats my rear wheel, hub, and muffler. In fact, anything over 3/4 between the lower and higher mark on the dipstick gives me blow out like that. So, if anything, it just creates a mess.
2011 Ural Patrol - Rodney
Gillette, Wy
Instagram: manscoutwyo
Users browsing this forum: No registered users and 6 guests
