Creeper gear? Any way to increase gear ratios from stock?
Eric N
Postby Eric N » Wed Oct 05, 2016 10:07 pm
I have a fast bike, don't need the Ural for speed, I'd actually prefer to lower it's speed a little and give it a granny gear.
Has anyone retrofitted higher gears to make the bike more crawler friendly? I'm cool with a top speed of 55mph but feel the stock first gear is a tad high for steep loose dirt and I'd rather not burn up a clutch.
I have from what I can tell stock gears on a 2001 Patrol 650. I lifted the rear tire and the driveshaft turns just shy of 5 spins for one spin of the wheel, I'm pretty sure it's the stock 4.62 final drive and my shifting pattern seems to match the stock range. She'll go 65mph no problem, I don't need it to go that fast.
I'm ok with the current gear spacing but wouldn't mind a higher gear in the final drive to make the bike a little slower and better for climbing offroad.
Has anyone swapped gears to either put higher gears in the tranny or a higher final drive? If so, where did you get the parts?
I tried searching for forum but seems people want to go the other direction and try to lower the gear ratio for highway and I want to go the opposite direction.
2013 Retro Solo
2001 Patrol - Sold
Bacon Andy
Re: Creeper gear? Any way to increase gear ratios from stock?
Postby Bacon Andy » Wed Oct 05, 2016 11:30 pm
:lurker:
Eric N wrote:I have a fast bike, don't need the Ural for speed, I'd actually prefer to lower it's speed a little and give it a granny gear.
80ish Kawa 650 LTD gone
76 Guzzi 850T-3 needs to go, parts bike
2004 Night Train, fast
2013 GU, loaded.
WTH? I've never had an original idea!
Bilgekeeldave
Postby Bilgekeeldave » Wed Oct 05, 2016 11:59 pm
Nope, they are what they are.
Dave
RAMCO-Dnepr MT-16
Postby gobium » Thu Oct 06, 2016 12:18 am
If there is a way mr. cob would have done it all already.
Ural in not atv
Good luck, ride safe.
Good bye all
made some great friends here
Postby jaybird » Thu Oct 06, 2016 10:39 am
Thats the holy grail of Ural driving, if you could get a little lower gearing for off road, and a little higher gearing for highway travel, these rigs would be "perfect".
The easy way to get a little lower gearing for off road would be to switch to a shorter wheel/tire combination, for example an 18" wheel with a 3.10x18 tire.
BTW, Extended driving at 65mph is a sure death for a Ural engine, I find that engines last longer if you don't exceed 4500 rpm (4000 rpm it will last "forever") for extended periods.
Install a tachometer, it's more reliable and useful than the speedometer.
Postby gobium » Thu Oct 06, 2016 11:10 am
Best solution
Good bye all
lomax
Postby lomax » Thu Oct 06, 2016 11:17 am
Just drop a tooth on the front sprocket. :lol:
84 R100RS LE,14 Ducati MTSGT,14 Hyperstrada, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR, 01 200EXC, 77 HD XLCR https://lomaxcm.smugmug.com/
Postby rivers » Thu Oct 06, 2016 11:36 am
gobium wrote:Best solution
Van you have a secret source for Zundap reduction boxes? :)
Tin Man
Postby Tin Man » Thu Oct 06, 2016 11:41 am
Many of have dreamt of a first gear that is 1/2 lower and a top gear 1/2 higher..... :foilhead: .....sadly it is nothing but a dream....... :(
2007 GearUp (Arctic #1)
LRP
Postby LRP » Mon Oct 10, 2016 9:45 pm
Drive components could not withstand the added torque. Just look at the diameter of the drive splines and driven splines in the wheel hub.
Ural has a chance to beef up the final drive now that they have disc brakes on the pusher wheel--they don't have to size the drive hub
and driven hub to fit inside a drum brake assy.
Army Bird Dog Pilot, Nam.
2018 CT
Traded '08 Patrol
19 previous motos
Eric N
Postby Eric N » Mon Oct 10, 2016 11:03 pm
Hi LRP,
I don't know the evolution of the drive components, I haven't seen a change in parts numbers for final drive from my 650 to the modern 750's but I haven't really looked. If it's correct that the modern components are interchangeable with the final drive parts on my 650, the drive components would be able to withstand a 20% increase in torque.
The specifications I've found for my 650 suggest it produces a max 34.7 foot pounds at 4800 rpm, a 2016 produces 42 foot lbs at 4,200 rpm.
I understand it might be unwise to increase the torque on the components above 42 foot lbs until there is a redesign, my engine is not that powerful.
2013 Retro Solo
2001 Patrol - Sold
LRP
Postby LRP » Wed Oct 12, 2016 4:32 pm
Hi Eric,
You have to take into account the reduction of the transmission and final drive in relation to torgue. By example, at 3750rpm torque peak of 37 lbft
of my 08 Patrol, 1st gear provides a reduction of 3.6:1. The 1st gear output, not counting frictional losses is 1041 rpm and 133 lbft.
Then going through the 4.6:1 final drive, 225 rpm and 611lbft arrives at the roughly 2" diameter splined drive hub.
Lets say you install a 7:1 final drive. It would deliver 931lbft. to the hub.
LRP
Dick
2018 CT
Traded '08 Patrol
19 previous motos
Burt1713
Postby Burt1713 » Wed Oct 12, 2016 5:26 pm
I don't know how something like this would last, but it would give you a crawler geared bike if it would fit in place of the driveshaft.
http://www.speedwaymotors.com/Howe-Raci ... 24447.html
2017 cT "Woody Moose"
Eric N
Postby Eric N » Wed Oct 12, 2016 5:59 pm
Hi LRP,
I think we're talking about two totally different bikes.
In my initial question, I'm using a 2001 Ural 650. If the drive train components haven't really changed over the years, and the old drive train components are interchangeable with the new ones, it could in theory take a 20% increase in torque without problem. That's not a 7:1, more like a 5.5:1 using the lower output of a 650 engine. I suspect if you crunch numbers using the 650 torque data and a 5.5:1 and match it to the stock setup on your bike, the numbers won't be too far off.
I have a co-worker who was previously in the gear making business. I'm going to ask his thoughts on a 7/37 gear set.
2013 Retro Solo
2001 Patrol - Sold
GregAus
Postby GregAus » Thu Oct 13, 2016 12:28 am
Available gear ratios for pre-Hertzog Ural gearbox. Some Dneprs had a 4.11 first gear and a guy named (I think) Tattoo Pluto fitted a 4.11 gear to his Ural. You can't fit that ratio to an electric start gearbox.
Gear ratios
        I               3.60                 3.20
        II              2.28                 2.08 1.71
        III             1.71                 1.56 1.30
        IIII            1.30                 1.19 1.00
        Rev 4.36
Final Drive        3.89                 4.62
viewtopic.php?t=11511 discusses the topic
Users browsing this forum: No registered users and 7 guests
