How to install a tach...
berger
Postby berger » Wed Feb 03, 2010 9:27 pm
Berger
2007 Ural Patrol (1st Owner)
Many, Many Mods.
Niteblues
Re: How to install a tach...
Postby Niteblues » Wed Feb 03, 2010 9:50 pm
That looked easy. :thumbsup:
But the tach isn't working in the picture! :oops:
Scott
2004 Ural Patrol
Mr Irish
Postby Mr Irish » Wed Feb 03, 2010 10:03 pm
Sweet!!!
thanks for the step by step.
Where did you get those hand guards?
:mrgreen:
Brian
Opposing symmetry on a regular basis….
2006 Ural Gear Up ~капиталистического участника
1998 Ural Deco ~Воскресенье езда мотоцикл
~Ranked 51 out of 124 on Ural National Rally Day 2011
My philosophy, in essence, is the concept of man as a heroic being, with his own happiness as the moral purpose of his life, with productive achievement as his noblest activity, and reason as his only absolute.~Ayn Rand
Who is John Galt?
berger
Postby berger » Thu Feb 04, 2010 8:25 am
niteblues59 wrote:That looked easy. :thumbsup:
It is, and I am an electrical newbie. The key was turned off..... :D
Berger
Many, Many Mods.
berger
Postby berger » Thu Feb 04, 2010 8:27 am
Mr Irish wrote:Sweet!!!
:mrgreen:
The handguards have been on since day one. I bought them as an extra and the dealer installed them. They are motorcross guards that also have a shield for the brake reservoir.
Berger
Many, Many Mods.
ickie
Postby ickie » Thu Feb 04, 2010 8:47 am
My fork nut was hollow and threaded, all I had to do was drill through the top of it, maybe 3/16 of an inch, than run a tap through it and install a bolt.
I have a spare nut and I will look to make sure its the same way. if so I will send it to you. PM me your address
"Its Was A Full Time Job, Being A 2000 Ural Patrol Owner" 650 cc, Pekar K-68 Carbs, Ducati Ignition, Extra Capacity Oil Pan, 40 AMP- 2 Circuit Fuse Box With Relay In Side Car, New Tach, New Cruise Control/Throttle Lock, New Nippon Denso Alternator, Trailer Hitch, New 2-Driving Lights, Harley Police Seat, New Custom Made Nylon Cover, 5 New Sachs Shocks, New Duro Tires.
ickie
Postby ickie » Thu Feb 04, 2010 9:15 am
here is a picture of my spare nut, note it isn't drilled out through the cap but its base is.
berger
Postby berger » Thu Feb 04, 2010 9:21 am
ickie wrote:here is a picture of my spare nut, note it isn't drilled out through the cap but its base is.
Thanks Ickie!
They must have changed them on the late model bikes, because mine is solid.
Berger
Many, Many Mods.
gimp4930
Postby gimp4930 » Thu Feb 04, 2010 9:08 pm
thanks for the information sir. something to add to my wish list.
the manual says max torque is at 3750 revs, rated rotational speed (maximum rpm?) 5600 revs
could some one with a tach post a table of speed/rpms?
60 kilometers = rpm :roll:
80 kilometers = rpm :)
100 kilometers = rpm :D
200 kilometers = rpm :bs:
I would be very interested in this information
Sean.
AKA IsAnOzzie on ADV
2008 Gear Up, a lefty
125/45 jets
Gossie needles
K&N filter
Home made Modtop style exhaust
Breather dribble tube
phenolic heat blocks
Raceway reverse shifter
Ahhhhh, police solo seat
3.5inch Rox risers, dey do fit
Heindl Tach
Saddle bags
Do or do not, there is no try = Yoda
berger
Postby berger » Thu Feb 04, 2010 9:24 pm
gimp4930 wrote:thanks for the information sir. something to add to my wish list.
Sean.
Hi Sean.
If nobody with a tach installed posts before me, I will try...once the weather warms up some... :D
Berger
Many, Many Mods.
gimp4930
Postby gimp4930 » Thu Feb 04, 2010 9:35 pm
thank you once again sir.
125/45 jets
Gossie needles
K&N filter
Heindl Tach
Saddle bags
URAL CT
Postby URAL CT » Thu Feb 04, 2010 10:38 pm
Here ya go gimp...ya just have to convert to KmPH :D
Charlie T... 8)
CT
2007 Patrol
Plano, TX
gimp4930
Postby gimp4930 » Thu Feb 04, 2010 11:20 pm
Brilliant, thanks
Sean
125/45 jets
Gossie needles
K&N filter
Heindl Tach
Saddle bags
heindlengineeringural
Postby heindlengineeringural » Fri Feb 05, 2010 10:38 am
Looks good to me
Heindl Engineering, LLC
Ural Dealer in Southwest Ohio
(937) 787-3686
www.heindlengineering.com
sales@heindlengineering.com
olimpiux
Postby olimpiux » Sun Feb 14, 2010 2:18 pm
Hi,
Is it possible to install a tachometer on an Ural 650 with the the Russian ignition type 3?
How should look the wiring scheme?
Thank you
IMZ Ural 8103-10 (650cc)
Year: 1991
Romania, Timisoara
