Oil Adaptor?
MonkeysUncle
Re: Oil Adaptor?
Postby MonkeysUncle » Wed May 16, 2018 10:48 am
I machined the adapter for my 2002 Tourist. Cross-over pipe is located just forward of the oil pan drain so no interference. Great mod, inexpensive filters available and easy to change.
My 2013 GearUp cross-over pipe interferes and I'd worry about possibility of heat transfer to the filter. I think the newer style timing cover is a better option. The spin-on adapter also makes adding an oil cooler easier. Here's a link to Gobium's video that might add some info.
https://www.youtube.com/watch?v=EMPbQlHAXwE
2002/2003 Tourist
2008 KLR650
2013 GearUp
dogboy443
Re: Oil Adaptor?
Postby dogboy443 » Wed May 16, 2018 11:33 am
I think I'm still SOL with my 2006 Tourist and the placement of the crossover pipe. I took some measurements and the crossover does not give me the clearance for even the shallow oil filter. Gotta stick with the paper filters.
2006 Ural Tourist, The Flying Pickle!
Re: Oil Adaptor?
Postby INSUBORDINATOR » Wed May 16, 2018 12:39 pm
dogboy443 wrote:I think I'm still SOL with my 2006 Tourist and the placement of the crossover pipe. I took some measurements and the crossover does not give me the clearance for even the shallow oil filter. Gotta stick with the paper filters.
You could perhaps find a decent early 750 set with crossover mufflers behind the transmission. Or use just the non crossover headers. Should run OK without the crossover.???
Think about it, & ask around. you already have the adapter (which I really like having) It still may work out.
ANYONE ELSE HERE RUN WITHOUT AN EXHAUST CROSSOVER ? I'm curious also.
Re: Oil Adaptor?
Postby Mr Wazzock » Wed May 16, 2018 3:56 pm
Rivers: “Pretty much a high end/rpm benefit which doesn't really pertain to a Ural motor or a lot of other twins.”
Have to agree. Probably cosmetic then. (?)
Re: Oil Adaptor?
Postby windmill » Thu May 17, 2018 1:38 am
The "H" type of crossover increases the exhausts efficiency, and decreases sound on low RPM engines, and is beneficial to a Ural for its entire usable RPM range. It's the "X" type of crossover that benefits efficiency on high RPM engines.
Explanations of the theory are widely available with a quick search, and it has been proven to work on a Ural through the empirical testing necessary to attain the EPA certification standards. If it didn't, IMWA wouldn't waste their limited resources on them.
Buckhorn
Re: Oil Adaptor?
Postby Buckhorn » Thu May 17, 2018 9:25 am
The Raceway exhaust 2 into 1 relocates the cross over, giving plenty of room for the stock filters.
2013 Ural Gear Up Gobi camo
Raceway 2 into 1 right side high exhaust, with Two Brothers muffler
Dimple drain plugs
Shorty left side directionals
2010 Harley Fat Boy
Arbee
Re: Oil Adaptor?
Postby Arbee » Thu May 17, 2018 8:59 pm
dogboy443
I've been running a high compression big bore with no crossovers for over a year. Removed them for a spin on filter. No difference IMHO
Ron
2005 Ural Tourist.
825 big bore kit
2013 heads
2013 exhaust
Modtop air filter
C5 programmable ignition with custom curves.
Dunstall replicas, Wideband air\fuel meter, drilled slides, manual petcock,
2 shims,Sean's Damper 45/152.5 jets,
2012 Harley Sportster 72 1200(garage ornament)
Return to “Modifications & Accessories”
Users browsing this forum: No registered users and 4 guests
